muck Posted March 17, 2011 Posted March 17, 2011 I am using AutoCAD 2010. I am trying to get the number of attributes in an AutoCAD Block. I am using the following code: For Each elem In ThisDrawing.ModelSpace If elem.EntityName = "AcDbBlockReference" Then If elem.Name = "SPREAD SHEET INFO" Then array1 = elem.GetAttributes 'attribct = UBound(array1()) c = 0 For k = 0 To UBound(array1()) Debug.Print array1(k) c = c + 1 Next k End If End If Next No luck with this code, Problem with UBound (array1()). So how do I get the number of attributes in a AutoCAD block? Thank you, Quote
