ummmmm......hummmm......errrrrr......\scratch....... what?
Put RM's lisp in a file.LSP, and put
(RM:CSV->Layers "H:\\acad\\AutoCad Custom Support Folder\\Lisp Files\\ArchExist.csv")
at the bottom (below everything).
  • Replies 61
  • waders
    11
  • alanjt
    8
  • pBe
    8
  • BlackBox
    6
I think the current question is what is entered in the keyboard to run the routine? Isn't a
(defun d:___ ()
missing?
if L= line, R= rectangle, what does one type to run the posted lisp?
(defun d:___ ()
)[\code]
if L= line, R= rectangle, what does one type to run the posted lisp?[/quote][code](defun c:GIMMIE (/) (RM:CSV->Layers "H:\\acad\\AutoCad Custom Support Folder\\Lisp Files\\ArchExist.csv") (princ))
Thank you alanjt! That is what I was missing. (both in the code and in knowledge)
- If all you have is a hammer, everything looks like a nail.
No problem.
You should look at the code I posted. It will allow you to just reference a drawing file and cut out a lot of typing.
(defun d:___ ()
missing?
Sometimes a subfunction offers more flexibility, since the user can create a multitude of wrapper functions to call it from, for example, another caller could be:
(defun c:test nil
 (RM:CSV->Layers (getfiled "Select CSV File" "" "csv" "16"))
Think of the 'RM:CSV->Layers' function as just another LISP function requiring a single argument (the CSV filename).
Consider the '+' LISP function - this takes several numerical arguments (or parameters):
(+ Arg1 Arg2 ... ArgN)
An Example call could be:
(+ 1 2 3)
Return: 6
Now consider this defined subfunction:
(defun Add2 ( x ) (+ x 2))
The above function takes a single numerical argument, 'x', and returns that number plus 2.
We can call the above function like any other LISP function:
(Add2 3)
Returns: 5
Lee
Okay I got this to work. Thanks for all this help. I couldn't ask for better service. Now next question. How do I Add the linetype import code in??
;; Linetype check
     [color=blue];; <- Add linetype import code here, to avoid errors[/color]
I posted a reply last night but unfortuantely my internet stopped as I pressed submit. This may be usefull to others wondering how do I not hard code a layer name into a lisp/vba program.
Any way I did something like you want but went a step further as we wrote a suite of programs and these were commercially available we had to allow the customer to use his layer names and colour and linetype. We also made a decision that the layers would be created dynamically only as required If you did not draw a wall then you had no wall layers. No need to load a 100 layers and then purge half of them back out again.
Now how to do it (sorry no code its copyrighted) you read your csv file and create 3 variables layer1-name layer1-col layer1-lt for each line in the csv you end up with a lot of variables but it works. the example below is the bit of code cut out of every lisp routine ie sets layer name based on a lisp variable not a layer hard coded into the lisp program
(setq lay_search roof--2)
(setq lay_colour roof--2col)
(setq l_type roof--2lin)
(lay_miss)
; check for missing layers on the fly
(defun lay_miss ()
within lay_miss it checks for layer name lay_search if not there creates with linetype and colour
So if drawing roofs using the program it knows the name of your roof layers having read it from the csv file.
You need an extra value in your csv file the name of your lisp variable
For the serious programers this has the advantage that you can write a program once but have the output vary depending the clients drafting rules.
Guess I'm too late :oops:
Anyways.... still using your original csv file format.
inicated "y" (lowercase) if frozen blank if not
(defun loadlayers ( csv / mLayer adoc layers ltype opf csv_lines ly_lst main_layer_list)
;;;  sample by pBE  ;;;
(vl-load-com)
(defun mLayer (lylst / Lnm nlt)
(foreach ln lylst
        (setq Lnm (vl-catch-all-apply 'vla-add
   (list layers (car Ln))
(vla-put-color lnm
          (if (= (atoi (nth 2 ln)) 0)
                             7 (atoi (nth 2 ln))))
       ([b]vla-put[/b]-description lnm (cadr ln))
       (if (= nil (tblsearch "LTYPE" (setq nlt (nth 3 ln))))
          (vla-add ltype nlt))
        ([b]vla-put-[/b]linetype lnm nlt)
        (if (eq (nth 5 ln) "n")
         ([b]vla-put[/b]-Plottable lnm :vlax-false))
        (if (eq (nth 6 ln) "y")
         ([b]vla-put[/b]-Freeze lnm :vlax-true))
(setq adoc (vla-get-activedocument (vlax-get-acad-object))
     layers (vla-get-layers adoc)
     ltype (vla-get-linetypes adoc))
(vl-load-com)
(setq opf ([b]open[/b] csv "r"))
([b]read-line[/b] opf)
(while
             (setq csv_lines (read-line opf))
  (while (setq parser (vl-string-search "," csv_lines))
    (setq
      line_pr
       (substr csv_lines 1 parser)
      ly_lst
       (cons line_pr ly_lst)
      csv_lines
       (substr csv_lines (+ 2 (vl-string-search "," csv_lines)))
       (if (> (strlen  csv_lines) 0)
          (setq ly_lst (cons csv_lines ly_lst)))
       (setq main_layer_list (cons (reverse ly_lst) main_layer_list)
           ly_lst nil)
([b]close[/b] opf)
(mLayer main_layer_list)
USAGE:
(LOADLAYERS "D:\\Layer Creater\\ArchExist.csv")
I opted not to check for existing layer, IMO company standards (if it is indeed a standard) is such because you need to adhere to it. so if by chance a user change a color.linetype on model space, running the routine will revert it back to its original,if theres any editing to be done with the layers might as well do it with VPLAYER
Also i would suggest to the OP to standardized color as integers and not string
(maybe thats why i had a hard time parsing the string :))
just my 2 cents
Edited by pBe
  • 10 months later...
I was able to get this lisp to work perfectly with the exception of pulling the LWeight of the layer from the .csv to AutoCAD. Any Ideas where I went wrong? I used the code that pBe uploaded as a base and the original .csv edited with my layer names, descriptions, colors, ltype and plot (on or off). I tried setting the lineweight to mm, inches and just a number value in the cell but it still didn't pull it into AutoCAD. Any help is appreciated!
I see in this .csv file lineweights aren't added
add them in appropriate column yourlsef, then
run something like:
;;; thanks to pBE
(foreach ln lylst
(vla-put-color lnm
       (vla-put-description lnm (cadr ln))
        (vla-put-linetype lnm nlt)
        (vl-catch-all-apply 'vlax-put (list lnm 'lineweight  (if (nth 4 ln)(atoi (nth 4 ln)))))
         (vla-put-Plottable lnm :vlax-false))
         (vla-put-Freeze lnm :vlax-true))
(setq opf (open csv "r"))
(read-line opf)
(while
    (setq
      line_pr
      ly_lst
      csv_lines
           ly_lst nil)
(close opf)
;;Autoload:
(loadlayers "D:/Programming/Lisp/LAYERS/Layer Creater_NT/ArchExist.csv");<-- change a path here
(vl-load-com)
Your .csv file must be looking like this, lineweights are as integers:
in the first line there is no linewieght, so this layer will be created
with default lineweight settings, e.g.:
A-ANNO,Architectural General Notes_ Key Notes,white,Continuous,,,
A-ANNO-CLNG,Ceiling General Notes_ Key Notes,white,Continuous,53,,
ETC ETC
Edited by fixo
code added
I used your code and created test.lsp and used the original ArchExist.csv file but inserted a few different variables into the existing columns to varify all columns were working. I still couldn't get the lineweight to pull in to AutoCAD with your .lsp code either. I have attached the two files that I used. Thank again for your imput!
Also...I noticed you have to put \\ inbetween folders for your filename in order for it to function properly. (ie: C:\\documents and settings\\desktop\\*filename*.csv
test.lsp
ArchExist.csv
Your problem is on the decimals is not allowed in vlax-put function I used
so you have to change:
A-ANNO,Architectural General Notes_ Key Notes,122,Continuous,0.09,n,y
on
A-ANNO,Architectural General Notes_ Key Notes,122,Continuous,9,n,y
and
A-ANNO-CLNG,Ceiling General Notes_ Key Notes,123,Continuous,0.03,n,
on
A-ANNO-CLNG,Ceiling General Notes_ Key Notes,123,Continuous,30,n,
as well as you are trying to add 0.03 see allowed values in lineweight
combo in the layer toolbar
say if you want use 0.53mm in this .csv file you have to use 53 without decimals
see attached file, lisp code is from my post above
ArchExist.csv
Edited by fixo
spell check
Works perfectly! I knew it was a user error and not a programmer error. I appreciate your help, sir! :D
You're welcome
Happy coding :)
  • 1 month later...
Okay a little help need to fine tune this code again. A big thanks to everyone that posted to help me out last time. What my question is why isn't the LWeight's being read from my .csv file? I'm attaching the files see below. I was looking at "fixo" code on this post and his works but it's in "mm" & not in "inches" and it won't override all the setting on the layers if they already exist in the drawing. Any ideas? Anyone? Thanks
archexist.lsp
ArchExist.csv
I will try to help just tomorrow, some my own things happened
Can you wait for?
Can you wait for?
Yes, that would be fine. I'm not in a big hurry. Thanks
How about edited lisp
see attached
Sorry didn't seem to fix it.
