Hi,
I work at an architecture firm, in which we have many drawings, all with multiple sheets. (A1, A2, A3...etc.)
I'm wondering, is there a way to lock which layers are visible based on the sheet you select?
For instance, I want to prevent someone from accidentally turning on HVAC information on a plumbing plan, if they do not check which sheet they are currently working in.
Is there a way to do this in a more permanent way, other than simply using the Freeze or thaw in current viewport button in the layer pulldown menu?
I hope that's not too confusing. Thanks everyone!
There is no way to do it with base AutoCad as far as I am aware. A lisp script could possibly achieve it (or warn against it at least) although it would probably be a hassle to most users.
