When we stretch a wall with hatch say, on the floor, how can I get the hatch to stretch with the wall?!?!?! :?
TIA
When you hatch, click the Associative hatch checkbox. It should stretch with the walls.
If it was hatched as unassociative hatch , then you are out of luck.
John
and even when it is associated I find it doesn't always go.
a times like that I just keep reminding myself how bad the hatching used to be.
ensure that associate hatch is on & then use STRETCH command AT GRIPS
  • 3 years later...
Bringing back a topic from the dead, but I had a similar problem with CAD '09. I selected the associate but the hatching still would not stretch with my wall. I played around with it and selected the "create separate hatches" under the associate and the stretching worked fine.
