angliru001 Posted March 28, 2011 Posted March 28, 2011 Help please! I've recently upgraded to LT2011, and now when I load xrefs, they don't seem to display in model view. Any suggestions gratefully accepted. Quote
rkent Posted March 28, 2011 Posted March 28, 2011 Do you see them in a layout tab, in a viewport? If you go to the modeltab you don't see the xref? Quote
angliru001 Posted March 28, 2011 Author Posted March 28, 2011 Sorry - didn't make myself very clear. I can't see the xrefs in model space. I design comms networks and usual method is to xref power authorities trenching plans as base layer and then add my design layers over. At the moment I can't see any sign of the xrefs. Thanks for quick response Quote
rkent Posted March 28, 2011 Posted March 28, 2011 The only difference between the releases that might cause this would be XDWGFADECTL, check help and then set to a number that might make it easier to see. You can adjust in options or typing the system variable. Quote
sparkyuk Posted March 28, 2011 Posted March 28, 2011 I might be wrong but have you tried zoom extents ? Quote
Organic Posted March 28, 2011 Posted March 28, 2011 Are you sure they are loaded/found properly? Quote
SLW210 Posted March 28, 2011 Posted March 28, 2011 _EXTERNALREFERENCES and see if it is showing in the manager. Quote
