Glen1980 Posted March 31, 2011 Posted March 31, 2011 I thought something like that must have happened as the new file was a few kb smaller than the original. Quote
dbroada Posted March 31, 2011 Posted March 31, 2011 it used to be a quick way of purging drawings as the purge command needed to be run for each nesting level. It was sometimes the only way to recover corrupt files. Quote
jaccna Posted April 2, 2011 Author Posted April 2, 2011 but WBLOCK will strip all redundant information (in effect PURGE the drawing). You may want this but if you have set up blocks and layers in readiness for the next stage you will need to recreate them after the WBLOCK instruction. Yes it is a double edge sword, but I have a menu pick that inserts a blank template and cancels before insertion, thus reloading any of your lost blocks or layers etc. Quote
nextvkin Posted April 12, 2011 Posted April 12, 2011 How about this - go to file, open, then instead of opening, select the file, hold the ctrl key, you'll get an instant copy. Cancel out of it & you're still in your original drawing. Quote
