mrbradley1 Posted March 30, 2011 Author Posted March 30, 2011 (edited) I've changed the "Displacement" to "" (defun C: DrawWeld () (setq len (getdist "\nSpecify length: ")) (setq ang 45.0) (setq obj-pt (entsel "\nSelect object: ")) (setq obj (car obj-pt)) (setq dist (getdist "\nSpecify distance between lines: ")) (command "_.COPY" obj "" "" "_NONe" (strcat (rtos len) "<" (rtos ang)) ) (setq tempobj (entlast)) (command "_.HATCH" "_User" ang dist "_No" obj tempobj "") (entdel tempobj) ) (C: DrawWeld) but it errors out after 'distance between lines' with the following:- Select objects: Specify base point or displacement, or [Multiple]: Point or option keyword required. ; error: Function cancelled Specify base point or displacement, or [Multiple]: any ideas? Edited December 3, 2013 by SLW210 Quote
Ahankhah Posted March 30, 2011 Posted March 30, 2011 mrbradley1, this code works in all versions of AutoCAD after Release 12: (defun C:DrawWeld () (setq len (getdist "\nSpecify length: ")) (setq ang 45.0) (setq obj-pt (entsel "\nSelect object: ")) (setq obj (car obj-pt)) (setq dist (getdist "\nSpecify distance between lines: ")) (command "_.COPY" obj "" "_NONe" (strcat (rtos len) "<" (rtos ang)) "" ) (setq tempobj (entlast)) (command "_.HATCH" "_User" ang dist "_No" obj tempobj "") (entdel tempobj) (princ) ) (C:DrawWeld) Please let me know you get the goal. Quote
Ahankhah Posted March 31, 2011 Posted March 31, 2011 That's it thanks., everyone You are welcome mrbradley1. Quote
