I am trying to make a scale bar block that allows user to input the scale and it automatically populates the scale bar numbers.
Note, I do not want to do a dynamic block with a list of preset scales that toggle visibility; I want the user to be able to input one field and have all the respective scale bar values calculated and updated based on that number.
I am having a problem making the numbers update correctly.
Attached is a screenshot of the block in the block editor (I cannot upload the 350kb cad file due to the website stating a limit of 250kb)
The block has one attribute - "mainscale" - where a user can enter the desired scale, default is 1000.
The mtext contain a field with a formula - the formula has a field targeting object-> "mainscale" -> value property, and divides it by 100 for 2nd bar value, by 50 for 3rd bar value, etc (to achieve the 10, 20, 30 when default value is 1000).
When I change the default value of "mainscale" within the block editor, the mtext values update correctly after a regen.
However when out of the block editor, after changing the "mainscale" value and regen the scale values do not update.
What am I missing to make the fields update on a regen when the attribute value is changed?
Or Is there some other way to create the scale bar with user input?
Do I need to use scripts to make this work?
Thanks in advance
(using Civil 3d 2011)
someone will offer you a more direct solution soon i'm sure, but in the meantime......
i would make this using layers (because it's simpler). draw all the numbers for scale 1:20 on layer called 1:20, freeze all the others off. simple, yes, but basic, i know.
hang in there, better answers will follow......... :)
@grant: regenall has same effect as regen, it just regen's all VP's and layouts, didnt resolve this issue.
@designerstuart: what you propose can be done with dynamic block, with each layer of scale on a separate visibility state. That is great when you only have specific scales in regular use (ie 1:100, 1:500, 1:1000, etc) and you can build one visibility state for each scale but that does not achieve what I am after, as that solution locks you into set scales.
