smorales02 Posted March 30, 2011 Posted March 30, 2011 So i have a house plan all drawn up, walls roofs, doors, etc..everything has a material added to it.. I am now having a problem creating sections/elevations, when i create them i dont see any hatching or anything on the walls and such, all i get is linework...what am i doing wrong?? Keep in mind that though i am not new to CAD this is the first time in a couple of years that i have used it and all my previous experience was using it in 2D civil drawings.. This is a test for a job i applied for where he wants us to reproduce one of his floor plans to see how quickly and accurately we can do it..So any and all help is appreciated.. Thank You Quote
Noahma Posted April 3, 2011 Posted April 3, 2011 There are a couple areas to check. First Right click on the section and go to "edit style" and look under display properties to make sure the hatches you want are turned on in there. Second would be to check in each material to see if the same thing is turned on. This should get you in the right direction. Quote
