I have an issue with items on the wall appearing in a detail view.
I have an electrical outlet mounted on the wall at 400mm which does not show in any clip range from 1 - 9000000
I have toggled everthing on the bottom left corner of the program, the closet that i get to finding something is when i toggle the detail level to fine, and it will show me essentially what i best describe as a 3d view of the obect. From there I have tried to edit the visibility of the family so that i can get a 2d view but to no avail.
If anyone has had this issue before and know a fix, it would be greatly appreciated.
Thanks in advance.
Figured it out, when drawing your call out view
in properties window click the drop down and select "Floor Plan" not "Detail"
