djole Posted March 30, 2011 Posted March 30, 2011 (edited) I want to loft the surface, made of polylines. The problem is that, when I select all the splines, and then do Draw-> Modeling -> Loft then I chose the "Cross-section only", this what kind of message I get in command box: The selected entities are not valid.Why is this happening? Here the .dwg file with the mentioned splines in it: http://www.gamefront.com/files/20173365/Kopie+von+Vorl%C3%A4ufiger+H%C3%B6henplan+H%C3%B6henbahn+Seenplateau.dwg Edited March 31, 2011 by djole Quote
ReMark Posted March 30, 2011 Posted March 30, 2011 Can you post the dwg file here? It would be a big help. Thanks. Quote
djole Posted March 30, 2011 Author Posted March 30, 2011 I tried doing it, but I can not attach it. The .dwg file is too big - 3MB, even when I zip it, it takes around 2MB, which is again too large for attachment. Can't you download it from the above link: http://www.gamefront.com/files/20173365/Kopie+von+Vorl%C3%A4ufiger+H%C3%B6henplan+H%C3%B6henbahn+Seenplateau.dwg Quote
djole Posted March 31, 2011 Author Posted March 31, 2011 this is what I get when I try to loft the polylines: Command: _u Loft GROUPCommand: Command: Command: _qsave Command: Command: Command: _loft Select cross-sections in lofting order: Specify opposite corner: 86 found Select cross-sections in lofting order: Enter an option [Guides/Path/Cross-sections only] : C Modeling Operation Error: Surface U and V derivatives are in the same or opposite direction. Modeling Operation Error: Surface U and V derivatives are in the same or opposite direction. The selected entities are not valid. I want to create a surface or solid out of those polylines (a montain slope). How can I do that? Quote
