Im dimensioning a building and press the continue button to continue the dimensions along a line of the building, is there any way of changing direction?
e.g up the building if dimensioning along the front wall without having to stop and press the dimension button then continue button again?
Technically you're not continuing the dimension. So you have to start a new Linear dimension to change direction.
