Spiderguy Posted March 31, 2011 Posted March 31, 2011 Hello! I have a problem/ question! My company uses tons of Xrefs - wonderful, however problem comes when having to navigate through 100's of layers to get to the main drawings layers. So I tried using the layer filters to just show my main drawings layers. Here is the problem, I you can select show all layers, not good, can select just the xrefs (show all of them or show just one of them, etc...), or you can show just the used layers - I tried that, but when you create a new layer it is not included in that filter. I tried setting up a custome layer filter, however, I don't know how to right the name or what selection to make that would allow me to exclude a set of layers. Anyone know how to fix this? Quote
designerstuart Posted March 31, 2011 Posted March 31, 2011 you can select xref only and then click the "invert filter" box bottom left of dialog box - any good? Quote
Spiderguy Posted March 31, 2011 Author Posted March 31, 2011 excelent! you know, if I had just looked around a bit! Thanks!!!!!! Quote
rkent Posted March 31, 2011 Posted March 31, 2011 Hello! I have a problem/ question! My company uses tons of Xrefs - wonderful, however problem comes when having to navigate through 100's of layers to get to the main drawings layers. So I tried using the layer filters to just show my main drawings layers. Here is the problem, I you can select show all layers, not good, can select just the xrefs (show all of them or show just one of them, etc...), or you can show just the used layers - I tried that, but when you create a new layer it is not included in that filter. I tried setting up a custome layer filter, however, I don't know how to right the name or what selection to make that would allow me to exclude a set of layers. Anyone know how to fix this? I found this lisp routine on one of the forums and have been using it ever since. Add it to your acaddoc.lsp file so it loads each time and you can type xrefnot and you have a filter that will work for what you want. Just another way to do the same thing. XREFNOT.LSP Quote
Spiderguy Posted March 31, 2011 Author Posted March 31, 2011 well, I have found an issue with the invert filter - it doesn't invert the filter for the drop down layer tool in the ribbon. I will have to ask our CAD manager to see if he would put that in our menu. Quote
kenboldt Posted May 30, 2011 Posted May 30, 2011 Create a new filter, and in the "NAME" column, enter (without the quotes) "~*|*" The tilde ~ means NOT The asterisk * is a wildcard Every Xref layer will have a pipe | in the name, so filtering for names that don't have a pipe | in them will leave just native layers showing. Note that the pipe | is not a lowercase L. It is a vertical line usually created with shift+\ Hope this helps. Quote
nestly Posted June 6, 2011 Posted June 6, 2011 well, I have found an issue with the invert filter - it doesn't invert the filter for the drop down layer tool in the ribbon. In the Layer Manager, go to Settings and check to see if "Apply layer filter to Layer toolbar" is checked. Quote
Spiderguy Posted June 27, 2011 Author Posted June 27, 2011 Kenboldt - it works perfectly ! nestly - I had tried that before, for some reason it doesn't work . Quote
tzframpton Posted June 27, 2011 Posted June 27, 2011 Create a new filter, and in the "NAME" column, enter (without the quotes) "~*|*" The tilde ~ means NOT The asterisk * is a wildcard Every Xref layer will have a pipe | in the name, so filtering for names that don't have a pipe | in them will leave just native layers showing. Note that the pipe | is not a lowercase L. It is a vertical line usually created with shift+\ Hope this helps. Beat me to it. This is exactly how I set my layer filter up too. Gotta love the Wildcard matches. Another tip, be sure to put this in your Template file so that you'll never have to keep recreating this layer filter. Quote
alexb119 Posted January 18, 2012 Posted January 18, 2012 New question: How can I get rid of all the xref-named filters? I mean' for each loaded xref, i see a filter. Thanks Quote
tzframpton Posted January 18, 2012 Posted January 18, 2012 New question:How can I get rid of all the xref-named filters? I mean' for each loaded xref, i see a filter. Thanks Type LA at the command line. Right click "All" under Filters, click "New Properties Filter". In "Filter Name" box, name it. I name mine "No XREF" Under Filter Definition > Name, type ~*|* and click OK. Make sure the new Filter is highlighted and close the Layer Manager. Check your Layer Dropdown, it should hide all XREF's now. *EDIT* Save this in your Template file so it's always there. Quote
alexb119 Posted January 18, 2012 Posted January 18, 2012 Thanks for replying, but this is not what I meant. I know how to hide xref layers from the display list. Again, the problem is that I see - for each xref - a filter bearing the name of the xref i.e. if I have 2 xrefs X1 and CHAIR, I see two filters named X1| and CHAIR|. Note the pipe after the name. The filters remain even after I delete, via a small lisp program, all filters. For each newly attached xref, a new filter appears and,conversely, detaching an xref erases the filter. How do I get rid of those? TIA Quote
kelbury Posted November 7, 2012 Posted November 7, 2012 Does anybody know how to set this layer filter as the default when you open a drawing (2013)? I xref the architects drawings into mine so my layer dropdown is filled with literally hundreds of layers from the xrefs. I never draw on this layers so not sure why they would be listed by default? I tried the lisp routing mentioned earlier in the thread but no workie. Quote
tzframpton Posted November 7, 2012 Posted November 7, 2012 I don't think you can. It's a known issue. Every time I open a drawing I have to set it manually - no matter what. Quote
