microwater888 Posted April 1, 2011 Posted April 1, 2011 Hi. I want to plot a sheet with viewport that's showing a Xref. The xref is beautifully colored however it will be plotted WITH all these colored lines. My questions is, without actually going into the xref file modifying all the lines and blocks into one color that my original file i'm working on would recognize the color and plot it the right way, can the xref be displayed as is and plotted differently? TYVM Quote
resullins Posted April 1, 2011 Posted April 1, 2011 When you go to plot, set your plotter as whatever device you're using, then hit Properties. Then go to custom properties.... somewhere in that dialogue box there will be a button that switches plotting to grayscale and/or gives you custom color controls. Alternately, if you go to File > Page Setup and select the page setup you want to use, click modify, in the upper right hand corner there's a button in "slot style table" that will open up a dialogue box and give you custom color controls over everything.... Quote
