Can someone point me in the direction of a good tutorial for the use of Solview and Soldraw please?
I am generating viewports using the solview command, but when i go to do the soldraw i keep getting the message "non-solview viewports ignored", even when i used solview to create the viewport. I am obviously missing something.
Not to take away from you wanting to learn SOLVIEW and SOLDRAW but it's an outdated way of sectioning. Have you tried the SECTIONPLANE command?
You can also use the FLATTEN command to generate 2D views of 3D objects.
i worked out the flatshot option, though i was just trying to learn something new. I get frustrated when i cant work something out lol.
Look for David Cohen's AutoDesk University 2010 handout for his lecture called Now Flatten This: Producing 2D Output from 3D models. It covers sections planes, flatshot and the commands solview, soldraw and solprof. The cousre number was AC322-3P.
good onya, thanks ReMark, Ill do some digging and see if i can find it.
