Is it possible to break multiple lines at a single point without a gap along a perpendicular line??
I believe this can (and has?) been done using a custom lisp routine. Now if only I could remember where I saw it.
nestly comes to the rescue.:thumbsup:
I knew there was something out there that would do the trick.
So i loaded in the lisp file.
Typed in breakobject, selected all the lines that i wanted to break and the line that i wanted them to break at but it only worked on the first line i selected.
Am i doing something wrong??
The lisp you loaded has several different routines within it depending on what you want to do, They're all loaded, just type the name of the one that matches what you want to do.
BreakAll - Break all objects selected with each other
BreakwObject - Break many objects with a single object
BreakObject - Break a single object with other objects
BreakWith - Break selected objects with other selected objects
BreakTouching - Break objects touching selected objects
BreakSelected - Break selected objects with any objects that touch it
BreakWlayer - Break objects with objects on a layer
BreakWithTouching - Break touching objects with selected objects
That is magic. worked perfectly. Cheers.
