Changing viewport size
How can we arrange sizes of windows when seperate one drawing to two or more viewport. I just couldnt find the way to change the size.
mview? create your own view ports (not sure I understand the question)
Viewports can be resized using their grips.
where are those grips I couldnt find them ?
Are you in model space or a paper space layout?
Modelspace viewports cannot be adjusted. You can get creative and find a happy medium. For instance, type -VPORTS at the command line and create three vertical Viewports. Initiate the command again and use the Join subsequent command to combine two adjacent Viewports together, giving you 66% drawing area in one, and 33% drawing area in the other. Hope this helps. ;)
yes I did that already by doing it 4 viewports-right and by using join command but still sometimes it is too smal sometimes too big. It is very interesting thing that we cant change it.
I agree. When I got into Rhino3D for awhile, I loved the fact you can adjust the viewports to your liking. I believe 3DSMax is the same. It would benefit plenty of people to have that same freedom in AutoCAD.
