bkuser Posted April 5, 2011 Posted April 5, 2011 Im currently using Autocad 2008 and am in the process of creating blocks for a friend who is using 2005, i have loads that need converting or writing so that they can be opened in 2005 and hopefully as a block can someone point me in the right dtrection please. cheers Quote
ReMark Posted April 5, 2011 Posted April 5, 2011 You will have to save them back to 2004 file format. I suppose you could batch process the whole ordeal via a script. Quote
nestly Posted April 5, 2011 Posted April 5, 2011 I have a lisp that's supposed to insert all dwg's in a directory into a single drawing as evenly spaced blocks. I've never used it as I already save my blocks in master drawings, but I tend to collect stuff like that. After all the blocks are in one drawing just save that drawing as AutoCAD2004 format. Quote
Patrick Hughes Posted April 6, 2011 Posted April 6, 2011 Download a copy of Dwg Trueview - it's a free viewer from Autodesk. It contains a utility called Dwg TrueConvert that will load a list of dwg files and convert to many different versions. Quote
Jack_O'neill Posted April 6, 2011 Posted April 6, 2011 Go to tools, options, then click on the open and save tab. There should be a pulldown menu that will allow you to change your default save format. Then it will save as the older version automatically. For the ones you've already done, you can write a script that will open and save each drawing in a directory. You can also have it purge, zoom extents, or anything else you'd like at the same time. There's probably a lisp routine floating around somewhere that will do that too. Quote
Jack_O'neill Posted April 6, 2011 Posted April 6, 2011 This link has a couple of different lisps. Word of advice: Make a copy of the directory you want to run this on before you run it, just in case it does something screwy. http://forums.augi.com/showthread.php?t=60673 Quote
bkuser Posted April 6, 2011 Author Posted April 6, 2011 Thanks for all the replies i will give them all a go and let you know how i get on Thanks Again Quote
