Crossing selection box not working in AutoCAD 2004
Not sure what I did, or turned off, but now I don't have the crossing selection box in my drawings. What do I do to get it working again please! :(
:oops:Good grief - Okay, I went to Options and re-checked "implied windowing" Now I can draw a crossing window, but it doesn't actually select the items. I usually can select an item then hit "E" to erase it; now I can select the item, but when I type "E" Cad prompts me to select an object. The crossing window doesn't register as a selection? Not sure what else to adjust to make it work correctly again. Help Pt. II
Edited by darrellk-1
Yup, it's set to "1". Also, when I select an object and go to the layers manager to change layers, it changes the layer for all items on the drawing. This is really screwed up. I was working with drawings from an architect that had proxy restrictions on copy and tried loading .arx files to see if that would help. Then all #$%^&! broke loose. :x
OMG! I have never ran across PICKFIRST command before. I changed it to 1 and now I seem to be back to normal. Your my hero, I have to finish this kitchen drawing by Thursday morning and had a panic attack!!
It is set at 0
It should be set to "1" as well.
