elevation problem
I was doing a fire protection system but suddenly my elevations changed it scales two times for example if its 2500 it shows 5000 how can I change it again?. I did ucs world but still nothing has changed
Did the system get knocked out of alignment? Is it indeed 2500 but it shows 5000? Or was it 2500 and it moved to 5000?
no it is in 2500 but I just couldnt understand why happens. For example when I entry 0 as elevation it puts itself to 2500 :s I already made the ucs to 0 but couldnt understand the problem
also it writes pipe sizes sometimes true sometimes wrong I mean reversed the value is true but the direction is wrong. How can I solve this issue?.
