I am working in 2010, recently switched PCs to a laptop, and had a menuload error with CAP 2020, our IT group unloaded and now we can't get it to reload. They are working on that issue, but in the meantime, he lost some of my settings, it switched me to classic mode instead of the standard 2010 ribbon bar mode. I switched to "initial set up" trying to get back to ribbon mode and it dropped all of the standard CAD toolbars that I had been using in conjunction with the ribbon bar yesterday (like print, copy, draw, offset, etc). any one have a suggestion for how to get these back? Thanks for your help!!!
AutoCAD Classic mode is a workspace. Did you try changing your workspace to something different?
If I switch to Classic Mode they do come back, but yesterday I had teh ribbons and the toolbars - not sure how it was set up that way. I am trying to get used to the ribbons, but the other made it a little easier. I may switch to CLassic if I can't figure the ribbons out.
thanks!
Have you tried typing the word RIBBON on the command line?
