I have recently started having a problem opening a file and saving a file as. I can open a file from windows explorer but when I try to open one from the "File - Open" menu AutoCAD locks up. Same thing happens when I try to "Save As".
AutoCAD 2008. Have you ever installed any updates for the program?
No. I have deleted and reinstalled the program and the problem will not go away.
Then you should first go to the AutoDesk website find, download and install the last update issued for 2008. Test the program. Come back here and report the results.
Downloaded the latest and it did not correct the problem.
Try turning off filedia (set to 0) does it work now (using command line to open or save files rather than dialog box).
Yes, that worked.....but surely this is not the fix!
