muck Posted September 30, 2008 Posted September 30, 2008 I am swiching from 2008 to 2009. In 2009 is there a way to make menu browser open with a hot key using Autolisp? thank you, Quote
neekcotrack Posted September 30, 2008 Posted September 30, 2008 I am swiching from 2008 to 2009. In 2009 is there a way to make menu browser open with a hot key using Autolisp? thank you, Why do you need a hotkey for the menu browser? You now you can get to it through the "A" in the upper left coner? (SEE BELOW FOR VISUAL) Quote
muck Posted September 30, 2008 Author Posted September 30, 2008 With a keyboard hot key you could tap a choosen key such as the "A" key and have all menu commands available. Since my left hand is allways on the keyboard for my other lisp routines I think a hot key for menu bowser would be a nice feature to have. I thought that would be nice feature to have all the commands in Menu bowser available without use of a mouse clicking on the red A icon. Other wise I will probably reset AutoCAD 2009 classic menu bar on top. Quote
neekcotrack Posted September 30, 2008 Posted September 30, 2008 With a keyboard hot key you could tap a choosen key such as the "A" key andhave all menu commands available. Since my left hand is allways on the keyboard for my other lisp routines I think a hot key for menu bowser would be a nice feature to have. I thought that would be nice feature to have all the commands in Menu bowser available without use of a mouse clicking on the red A icon. Other wise I will probably reset AutoCAD 2009 classic menu bar on top. These commands will open it: ALT+(F,E,V,I,O,A,X,W,H) If you look at the work ther is a line under a word. If you hold the ALT plus the letter you see is will open it to that menu. Good luck. Quote
muck Posted September 30, 2008 Author Posted September 30, 2008 The Alt hot keys that you mention are good for the classic menu bar when menubar variable is 1. If menubar is 0 then menu browser will pull up. If there a way to activate the object bowser menu with menubar variable set to one. I do not see an underscore for the big red "A". How could that be set to an single key such as the "A" key without using the ALT key in lisp. I think there might be a way to do that? Thank you, Quote
