mistryman Posted September 30, 2008 Posted September 30, 2008 I am trying to draw a curve using 3D polylines whereby the lines are connecting to the nodes. I have used the spline command but when doing this, the curve line does not connect onto the nodes, but floats around them. I am wanting the curve to connect to the nodes. Does anyone know how to do this? Thank you! Quote
ReMark Posted September 30, 2008 Posted September 30, 2008 Just out of curiousity, if you "Fit" the curve does in hit all the nodes? Quote
eldon Posted September 30, 2008 Posted September 30, 2008 If you draw a 3D Polyline, only line segments are drawn, which then have to be curve fitted as a spline. This process pulls the curve away from the nodes, and it is all thoroughly explained in the help section. If you want your curve to stay at the nodes, then you have use the SPLINE command in the first place. Quote
Least Posted October 1, 2008 Posted October 1, 2008 Does anybody have a lisp which can convert 3dpolylines into splines please? I have found lisps which convert splines to polylines, but not the other way around. ta Least Quote
