andycarpenterf1 Posted September 30, 2008 Posted September 30, 2008 Hi to all in autocad land. I have picked up a drawing drawn by a member of the dept i work in and whilst checking the dimensions i exploded one to see if they are associative and everything just disappeared. Is there a command that stops this from happening. Drawing was done dont laugh in Autocad release 14. We are all on different versions of autocad ranging from Autocad release 14 to lt 2006. Looking forward to a response shortly. andy carpenter Quote
Tiger Posted September 30, 2008 Posted September 30, 2008 Why on earth would you want your dimensions exploded???? Quote
BOB'27T Posted September 30, 2008 Posted September 30, 2008 All you need to do is select a dimension and it will tell you in the properties if it's associative or not. Quote
