CiCAD Posted April 13, 2011 Posted April 13, 2011 Is it possible to change the colour of text below a dim line but have the text above the dim line remain the colour of the layer? Quote
Pablo Ferral Posted April 13, 2011 Posted April 13, 2011 Something similar came up on Edwin Prakoso's Blog recently: http://cad-notes.com/2011/04/autocad-tip-remove-alternate-unit-bracket-in-dimension/ Adding the font colour into the ‘Alternate units – Prefix tab’ will allow you to Style the Alternate Value: eg ;\fCentury Gothic; \C1; Let me know how you get on! Quote
nestly Posted April 13, 2011 Posted April 13, 2011 Is it possible to change the colour of text below a dim line but have the text above the dim line remain the colour of the layer? The simplest way is to add \X\C1 as a primary units suffix, and set alternate units to "After primary value" The \X switch forces the alternate units below the dimension line, and \C1 sets the color to red (or \C2 for yellow or \C3 for green etc) You can do this either as a dimension override in the Properties palette, or on the primary units tab of your dimstyle. There are other options to change only the color inside the alternate brackets, and to suppress the alternate brackets entirely. Quote
CiCAD Posted April 13, 2011 Author Posted April 13, 2011 Great!!! Works like a treat! now i ask is there a way of putting a box around the text below the line? And not the text above the line? is there a way of creating a dim stlye where i can have text below the line. i know i can set up dim styles to have a set prefix and suffix Quote
CiCAD Posted April 14, 2011 Author Posted April 14, 2011 any way i can asign a colour that is not a standard colour. eg a colour other then the general colours red blue cyan magenta Etc Quote
SLW210 Posted April 14, 2011 Posted April 14, 2011 I haven't tried it, but all the colors have a number. Just find the color you want and you should see the number. Quote
