Erasing the text in the 2nd line of an Mtext
Not necessary, in case DXF 1 started with either "\\P" or "\n" and the next line of text didn't start until somewhere within the DXF 3 block perhaps.
254+ characters later
  • Replies 27
  • alanjt
    11
  • Lee Mac
    6
  • LearningLisP
    5
  • Tharwat
    2
Posted Images
*shrug* just throwing it out there :)
My point was that if we're using the filter within ssget (since it only searches the first matching pair), it's kind of pointless to step through the entire entity data dump when it's only concerning itself with the first.
Boy, you will argue with a post. LoL
Just for grins and giggles (using my modded example):
(defun c:test (/ ss i e s)
 (vl-load-com)
 (if (setq ss (ssget "_:L" '((0 . "MTEXT"))))
     (if (cond ((vl-string-search
                  "\\P"
                  (setq s (apply 'strcat
                                 (mapcar '(lambda (x)
                                            (if (vl-position (car x) '(1 3))
                                              (cdr x)
                                         (entget (setq e (ssname ss (setq i (1- i)))))
               ((vl-string-search "\n" s))
       (vla-put-Textstring
         (vlax-ename->vla-object e)
         (car
           (vl-remove
             (read
               (strcat "(\"" (LM:StringSubst "\" \"" "\\P" (LM:StringSubst "\" \"" "\n" s)) "\")")
(defun LM:StringSubst (new old string / l i)
 (setq l (strlen new)
       i 0
 (while (setq i (vl-string-search old string i))
   (setq string (vl-string-subst new old string i)
         i      (+ i l)
 string
wow.. i thought this was solved.. :).. you guys are genius!! thanks!
@Thalwart
ah ok.. maybe it wont work in an older version. thanks!
hey alan, tested your code and unfortunately, it did not work on me. i guess its my CAD version. thanks for updating it. :)
  • 2 years later...
Can you please suggest us how can we delete last line of the AutoCAD mtext by a single click through lisp file. Thanks in advance!
  • 5 years later...
IS THERE ANY CHOICE OPTION, any one can provide a lisp
MAY BE IN SOME MTEXT I WANT REMOVE ABOVE 2 OR 3 LINE
MAY BE IN SOME MTEXT I WANT REMOVE BELOW ONE LINE (2 OR 3) .
*** MUST BE ASK CHOICE  (FROM ABOVE 1,2,3......OR FROM BELOW 1,2.3.....) LIKE THAT
THANKS
