I need a LISP that extracts "Length" and "Angle" from multiple lines, so I can transfer them in a word/excel format.
I would of used _DATAEXTRACTION, but here at the office we use AutoCAD 2006, and as some may know, AutoCAD 2006 doesn't have the _DATAEXTRACTION option.
I my case I have 2D geometric shapes, drawn with polyline only. Also I have a point. I need to draw from that point, lines to every polyline turning and then extract the Length and Angle from those lines.
I have a LOT of this kind of shapes daily, so doing this manually every day is a real pain.
Here's an image attachment for better understanding my situation.
  • Replies 22
  • pBe
    7
  • SlopeSilviu
    5
  • Lee Mac
    4
  • JohnM
    3
Posted Images
Do all of the lines from the point connect to each vertex of the polyline shape above?
Do the collections of lengths and angles have to be in a specific order?
Sorry, I forgot to mention this.
Every line is independent, drawn from the point to the polyline vertex.
EX: -point is X
-vertexes are 1,2,3,4,5,6
All lines are drawn from X to 1, next line from X to 2, next line from X to 3, and so on.
I'm sorry, Ill check that out.
@ SlopeSilviu: Isn't this the same post as your other one?
Extracting Length & Angle
Getting an idea of what I do:
I have the base point X and the secondary points from lets say 1 to 20 (total of 21 points)
I draw lines from X to every one of the secondary point (from point X to point 1; from point X to point 2; from point X to point 3; ........from point X to point 20)
If you click proprieties on one of the lines, you will see that it has a Length and an Angle.
I need to manually copy the length and the angle of every line, and paste it in a table on Excel/Word.
Problem:
I have about 100 points a day of this kind, so manually copying their length & angle is a real pain.
Is there any way faster to do this. A specific command in AutoCad (2006)
I was thinking if anyone know a name of a certain LISP, or if someone possess one that can help me with this problem.
If I wasn't specific enough, I will submit an example.
Approximately, yes, but it has some different base lines.
Also I got to the conclusion that only a LISP can help me, so I "remade" a post here.
I just threw this together for fun
Why not have it do as much as possible.
This will draw the lines to each vertex and make a comma-separated file named lineinfo.txt located on “C:\”
After running the program open excel and import the txt file.
(defun c:mklns (/ pt1 ss ent lsttxt txlst ff)
       (setq pt1 (getpoint "Pick The Point"));_base point
       (setq ss (ssget '((0 . "LWPOLYLINE"))));_polyline object
       (if ss
       (setq ent (entget(ssname ss 0)));_entity info for poly object
       (foreach item ent
(if (= (car item) 10)
       (command "pline" pt1 (cdr item) "");_draw lines
       (setq lsttxt (strcat               ;_make comma seperated list of length and angle
       (rtos(distance pt1 (cdr item)))
       (angtos (angle pt1 (cdr item))0 4)
       );_strcat
       );_setq
       (setq txlst (cons lsttxt txlst));_compiled list of all line length and angles
       );_progn
       );_if
       );_foreach
(setq ff (open "C:/LineInfo.txt" "w"));_write to file
(foreach item txlst
       (write-line item ff)
       );_foreach
       (close ff)
       );_progn
       (alert "No Polyline Object Selected")
       );_if
       );_defun
Thank you John for the quick reply.
I tried to load the LISP, and it does load, but it doesn't do anything, maybe a command line is missing something, or there must be something I don't understand.
Here's a picture: 123123.jpg
I hope it's just me being stupid...
(defun c:test (/ adoc Pline Xpoint PtList PtAngleList NewLine)
  (vl-load-com)
  (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
(if (setq Pline (car (entsel "\nSelect Pline:"))
        Xpoint (getpoint "\nSelect \"X\" Point: "))
  (setq PtList (mapcar
                'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) (entget Pline))))
(setq PtAngleList (open (strcat (getvar 'Dwgprefix)(vl-filename-base (getvar 'Dwgname)) ".csv") "A"))
  (foreach Pts (cdr PtList)
       (setq NewLine (vla-addline (vlax-get (vla-get-activelayout adoc) 'Block)
          (vlax-3d-point Xpoint) (vlax-3d-point Pts)))
       (write-line (strcat (rtos (vla-get-length NewLine) 2 2) ","
                       (rtos (vla-get-Angle NewLine) 2 2)) PtAngleList)
       (print PtAngleList)
  (close PtAngleList)
Here's a picture
Type MKLNS to run the Lisp after you have loaded it.
Copy the code from this post
Paste it into notepad
Save the notepad as “test.lsp” (use the quotes in the save as dialog to save type as .lsp)
In AutoCAD appload the test.lsp
Type mklns on the command line
For a quick test: copy the source from the forum and paste it in AutoCAD's command line. Next type the name (klns) to start it.
If you saved the lisp file, you may load it using the Appload command, or just drag the file in AutoCAD's drawing area.
(defun c:test (/ CreateList _grAngle adoc Plines obj cnt ent ObjectPointList
                PtAngleList Xpoint gr NewLine
;;; pBe April 2011  ;;;
 (vl-load-com)
 (defun CreateList (p)
   (setq ObjectPointList (cons (cdr p) ObjectPointList))
;;;  Alanjt  ;;;
 (defun _grAngle (a b)
   (grdraw (trans a 0 1) (cadr gr) 1 -1)
   (angle a b)
 (if (setq Plines (ssget ":L" '((0 . "LWPOLYLINE"))))
      (repeat (setq cnt (sslength Plines))
        (setq obj (ssname Plines (setq cnt (1- cnt)))
          ent (entget obj)
        (mapcar 'CreateList
          (vl-remove-if-not '(lambda (x) (= (car x) 10)) ent)
        (ssdel obj Plines)
(if ObjectPointList
;;;  Alanjt  ;;;
          (while (eq 5 (car (setq gr (grread T 15 0))))
            (setq Xpoint (trans (cadr gr) 1 0))
            (redraw)
            (foreach pts ObjectPointList (_grAngle pts Xpoint))
          (redraw)
          (foreach
             itm ObjectPointList
            (setq NewLine
               (vla-addline
                 (vlax-3d-point itm)
        (close PtAngleList)
pBe,
Some constructive criticism, I hope it helps: note that there is no need for the angle calculation within the grRead loop, since you are not using the return of '_grAngle', also, it might be quicker to use the distance and angle functions when measuring the length and angle of the lines.
This is how I might go about it:
(defun c:test ( / e fl gr i pt pu pw ss )
 (if
   (and
     (setq fl (getfiled "Output File" "" "csv" 1))
       (foreach x (entget (setq e (ssname ss (setq i (1- i)))))
         (if (= 10 (car x))
           (setq pw (cons (trans (cdr x) e 0) pw)
                 pu (cons (trans (cdr x) e 1) pu)
     (while (= 5 (car (setq gr (grread t 13 0)))) (redraw)
       (setq pt (cadr gr))
       (foreach x pu (grdraw x pt 1 -1))
     (setq pt (trans pt 1 0))
     (if (setq fl (open fl "w"))
         (foreach x pw
           (entmakex (list (cons 0 "LINE") (cons 10 x) (cons 11 pt)))
           (write-line (strcat (rtos (distance pt x)) "," (angtos (angle pt x))) fl)
         (close fl)
 (redraw) (princ)
Your criticism does help a lot and always welcome. I was wondering back then why i keep getting an error after (while... grread...) line using (cond...) . thanks for the heads up.
I was thinking of eliminating the creation of the LINE altogether and used distance and angels from the point list since the purpose of the code is to write datas into a file.
I recognized the value of your criticism Lee.
Tnaks a mil
To eliminate the issue of not being able to use running osnap
(defun c:test ( / e fl gr i pt pu pw ss Op accept )
 (if
   (and
         (if (= 10 (car x))
    [color=blue](while (not accept) [/color]
[color=darkolivegreen] (setq pt (getpoint "\nSelect Point: ") op nil) [/color]
[color=blue]  (foreach x pu (grdraw x pt 1 -1))[/color]
[color=blue]  (while (not (member Op '(97 32))) [/color]
[color=blue]    (princ "\n<A>ccept Spacebar for other point")(princ)[/color]
[color=blue]  (setq Op (cadr (grread))))[/color]
[color=blue]     (if ( = Op 97)(setq accept T))[/color]
[color=blue]    (redraw))[/color]
[color=darkolivegreen](setq pt (trans pt 1 0))[/color]
         (foreach x pw
         (close fl)
 (redraw) (princ)
Edited by pBe
Trans function location
Nice idea!
Beware of (trans nil) and also that grdraw uses UCS points :)
Another way might be to use getkword:
(defun c:test ( / e fl gr go i pt pu pw ss )
 (if
   (and
         (if (= 10 (car x))
     (while (and (not go) (setq pt (getpoint "\nSpecify Point: ")))
       (redraw)
       (initget "Yes No")
       (setq go (/= "No" (getkword "\nAccept Point? [Yes/No] <Yes>: ")))
     (if (and pt (setq fl (open fl "w")))
         (foreach x pw
         (close fl)
 (redraw) (princ)
Nice idea!
Your dead-on about the trans Lee (modified the code) tnx
Can you explain to me the horrors of Grdraw with regards to UCS points
Thats better :)
Sorry, what do you mean about the 'horrors of Grdraw with regards to UCS points'?
