neekcotrack Posted September 30, 2008 Posted September 30, 2008 I have a lisp right now that opens explore to the location of the current drawing open. (defun c:xpl () (startapp "explorer" (strcat "/n,/e," (getvar "dwgprefix"))) (princ) ) Let’s say the location is: J:\2008\01080\dwgs\electrical I am trying to get it to do the following: 1. Bind and purge the Current drawing. 2. Ask user Where to Save? Bound or E-Mail a. If boundis picked then save in this location with current name J:\2008\01080\bound\ (Current Date)\ (Current Name).dwg Note. If folder is not made already, create folder first. The date folder will be formatted like this 2008-09-30 b. If E-Mail is picked then save in this location with current name J:\2008\01080\E-Mail\ (Current Date)\ (Current Name).dwg Note. If folder is not made already, create folder first. The date folder will be formatted like this 2008-09-30. 3. Exit the Drawing I hope this makes sense to someone other than me. Thanks in advance to everyone. Quote
bsamc2000 Posted October 1, 2008 Posted October 1, 2008 Its not pretty but this should get you started. It does not bind or purge the file but you should be able to add that. I only had about 10 minutes to work on it. You should also add some error trapping. I hope it helps. (defun c:BindIt ( / ) (setq vDia (getvar "filedia") vEcho (getvar "cmdecho") vPrefix (getvar "dwgprefix") vName (getvar "dwgname") vDate (rtos (getvar "cdate") 2 6) vYear (substr vDate 1 4) vMonth (substr vDate 5 2) vDay (substr vDate 7 2) vDateStr (strcat vYear "-" vMonth "-" vDay) ) (setvar "filedia" 0) (setvar "cmdecho" 0) (initget 1 "Bind Email") (setq vAns (getkword "\nSave file to [Email / Bound] <Bound>: ")) (cond ((= "Bind" vAns) (setq vDir (strcat vPrefix "Bound")) ) ((= "Email" vAns) (setq vDir (strcat vPrefix "Email")) ) ) (if (= (vl-file-directory-p vDir) nil) (progn (vl-mkdir vDir) (vl-mkdir (strcat vDir "\\" vDateStr)) ) (if (= (vl-file-directory-p (strcat vDir "\\" vDateStr)) nil) (vl-mkdir (strcat vDir "\\" vDateStr)) ) ) (command ".saveas" "" (strcat vDir "\\" vDateStr "\\" vName)) (setvar "filedia" vDia) (setvar "cmdecho" vEcho) (princ) ) Quote
neekcotrack Posted October 1, 2008 Author Posted October 1, 2008 Its not pretty but this should get you started. It does not bind or purge the file but you should be able to add that. I only had about 10 minutes to work on it.You should also add some error trapping. I hope it helps. (defun c:BindIt ( / ) (setq vDia (getvar "filedia") vEcho (getvar "cmdecho") vPrefix (getvar "dwgprefix") vName (getvar "dwgname") vDate (rtos (getvar "cdate") 2 6) vYear (substr vDate 1 4) vMonth (substr vDate 5 2) vDay (substr vDate 7 2) vDateStr (strcat vYear "-" vMonth "-" vDay) ) (setvar "filedia" 0) (setvar "cmdecho" 0) (initget 1 "Bind Email") (setq vAns (getkword "\nSave file to [Email / Bound] <Bound>: ")) (cond ((= "Bind" vAns) (setq vDir (strcat vPrefix "Bound")) ) ((= "Email" vAns) (setq vDir (strcat vPrefix "Email")) ) ) (if (= (vl-file-directory-p vDir) nil) (progn (vl-mkdir vDir) (vl-mkdir (strcat vDir "\\" vDateStr)) ) (if (= (vl-file-directory-p (strcat vDir "\\" vDateStr)) nil) (vl-mkdir (strcat vDir "\\" vDateStr)) ) ) (command ".saveas" "" (strcat vDir "\\" vDateStr "\\" vName)) (setvar "filedia" vDia) (setvar "cmdecho" vEcho) (princ) ) Is there any way to have it go back two folders to save the folder bound or e-mail? Example: M:\1234\dwgs\electrical and I want it to save the folders in the 1234 folder that would be two folders. You can also think of it as the folder before the dwgs folder to. Thanks in advance for everything. Quote
CAB Posted October 1, 2008 Posted October 1, 2008 Not my code but here is one way. You can even create a new folder. (defun ALE_GetFolder (/ DirPat) (and (setq DirPat (getfiled "Browse for folder" "Open a folder and click on SAVE" " " 1 ) ) (setq DirPat (substr DirPat 1 (- (strlen DirPat) 31))) ) DirPat ) Quote
neekcotrack Posted October 1, 2008 Author Posted October 1, 2008 Not my code but here is one way.You can even create a new folder. (defun ALE_GetFolder (/ DirPat) (and (setq DirPat (getfiled "Browse for folder" "Open a folder and click on SAVE" " " 1 ) ) (setq DirPat (substr DirPat 1 (- (strlen DirPat) 31))) ) DirPat ) You lost me! Quote
neekcotrack Posted October 2, 2008 Author Posted October 2, 2008 You lost me! Does anyone know what I am talking about? Quote
neekcotrack Posted October 7, 2008 Author Posted October 7, 2008 Out of town until Monday. Sorry been busy. Quote
