Hello Everyones. I have one prolem with this code. Can u help me slove that.Thanks much.
I am try to select block and will add it into blockedit workspase with 1 command by the command : -refedit. But i can't add the entity in command.
Code:
Sub BlockTest()
Dim obj As AcadBlockReference
Dim inspt As Variant
ThisDrawing.Utility.GetEntity obj, inspt, "Select object:"
If TypeOf obj Is AcadBlockReference Then
ThisDrawing.SendCommand "_refedit " & _
"(handent " & Chr(34) & obj.Handle & Chr(34) & ")" & _
vbCr & "o" & vbCr & "a" & vbCr & "y" & vbCr
Else
MsgBox "You did not select a block."
End If
End Sub
Edited by phamduyanh
mistask
I moved the request in the VBA forum -more chances here to get it answered.
