edgley Posted April 14, 2011 Share Posted April 14, 2011 Hi, I have just switched from Pc to Mac with AC. Not sure if its the platform change, or the later version, but I am having problems doing things I used to have no problems doing! I have duplicated a layout, but when I click on the inside of it it wont make it active and allow me to zoom the view. If I create a new layout, I can click inside and zoom, however, in this instance, its quick for me to duplicate and re-zoom, if only I could I have tried the MV > L > off command, but that is wanting me to select an object, and not unlock the whole layout. Same thing if I hit the lock or freeze button on the right hand tool panel. Thanks, Simon. Quote Link to comment Share on other sites More sharing options...
Ohnoto Posted April 14, 2011 Share Posted April 14, 2011 Are the viewports on top of each others? You can use ctrl+r to switch between viewports. Quote Link to comment Share on other sites More sharing options...
Rebel Posted April 14, 2011 Share Posted April 14, 2011 (edited) add "all > enterx2" to your command to unlock all the viewports on that layout: MV > L > off > all enterx2 Edited April 14, 2011 by Rebel Quote Link to comment Share on other sites More sharing options...
edgley Posted April 14, 2011 Author Share Posted April 14, 2011 ctl /cmd r didnt do anything, adding All returnx2 did fix it. Thank you so much Quote Link to comment Share on other sites More sharing options...
