DIW_HDsupply Posted April 15, 2011 Posted April 15, 2011 I have a tough one for some of you... I have created a valve, and an adapter. The addapter conserves space between two MJ parts.. I.E. MJ valve to MJ Tee. Lay Length of the adapter is effectively 1" from bell to bell or CEL of Valve plus 1" Plus CEL of fitting. When I use the adapter with two fittings I have no issues.. however when I use it with my valve .. it mysteriously dissapears. The same thing happens with a PLUG I created... See the screen shot below On the Right you see the valve on the left you can see 2 water lines.. of the two they are identical only the one on the Left I have deleted the valve... http://dl.dropbox.com/u/20790817/Screenshot_Phantom_Parts.jpg Thus... Phantom parts.. Also when I try to copy the items the "invisible" items sometimes don't copy... Any suggestions? Quote
