flip normals problem
when I convert to poly, select all and flip normals, the object turns black and I cannot see inside the object, does anyone know why this is?
thank you to anyone with an answer
Select the model, right click and choose "Object Properties".
In the Properties window > General Tab > Display Properties > Put a check in the "Backface Cull" box.
Thanks very much for that Cad64, you are the man with lots of answers, cheers
