I need the attached image of the macro or add-on this issue can you help?
I saw these pictures on the internet and could not find a plug-in spite of many seeking. I need the attached image of the macro or add-on this issue can you help?
What version of Inventor are you using?
Try starting a new 3D Sketch and see if you have the option to import the xls.
I use inv2010 version but I don't want to import only point I want to import xls spline,polyline and point.I think this is an addins or macro please help me?
Edited by ses4
You must not have tried my instructions.
What happens if you do a 3D sketch and you select the option to create a spline from the imported xls points.
What version of Inventor were the screen captures you posted from?
2010 should allow you to import the xls points into a 2D sketch (x and y) or into a 3D sketch (x, y, z).
No add-in needed.
