Adjusting Grid of Cross-Sections
I am doing around 25 cross-sections of a road in civil 3d 2007. I can't find a way to manually set the max and minimum elevations i would like to show. Currently I have only been able to set the number of grids to appear beneath the lowest point in each cross-section.
Is there a way to override this manually like you can do with profiles? I'm stumped and it would seem ridiculous that there is no answer.
thanks.
Right click on the section, then select section view properties. Pick the elevations tab, then change it to user specified elevations. I hope this will help!
there's no 'elevation tab'
here's the tabs in order...
information, graph data, sections, bands, pgl
That's weird. Mine is between graph and sections. It seems like your tab is missing for some reason. I'll do some more checking into this for you.
yeah it certainly feels like something is missing
Try going into "Create Section View". Then go to "elevation range". You can change the elevation heights there.
