barrowfordred Posted April 19, 2011 Share Posted April 19, 2011 Solidworks 2008 : Is it possible to insert a lamp in a model and have directional light that always shines out of it (as it would from a real lamp) no matter where you move the lamp to? I can add light to a model but not as above. Thanks Quote Link to comment Share on other sites More sharing options...
Quagga Posted April 19, 2011 Share Posted April 19, 2011 Not sure if you can. on another note are you a communist living in Barrowford? or just a redhead? Quote Link to comment Share on other sites More sharing options...
shift1313 Posted April 19, 2011 Share Posted April 19, 2011 go to View>Lights and Cameras>Add Direction Light(or spot light). In the Light position section there will be a "lock to model" option. I only used SW08 for about a month but i believe this is still there as long as you have the photo rendering Add-in turned on. Quote Link to comment Share on other sites More sharing options...
barrowfordred Posted April 20, 2011 Author Share Posted April 20, 2011 Tried this, it's locks the light to the assembly position not to a part in the model. Thanks anyway. go to View>Lights and Cameras>Add Direction Light(or spot light). In the Light position section there will be a "lock to model" option. I only used SW08 for about a month but i believe this is still there as long as you have the photo rendering Add-in turned on. No. Neither Am I now I've tried the above. Red is a reference to my football affiliation ;-) on another note are you a communist living in Barrowford? or just a redhead? Thanks all anyway. Quote Link to comment Share on other sites More sharing options...
