muck Posted April 19, 2011 Posted April 19, 2011 Program, AutoCAD 2010 VBA I normally use the following code to get attributes from a drawing. Public Sub array1Initialize() For Each elem In ThisDrawing.ModelSpace If elem.EntityName = "AcDbBlockReference" Then If elem.Name = "SPREAD SHEET INFO" Then array1 = elem.GetAttributes DrawingAttributeCT = 0 For j = 0 To UBound(array1) 'Debug.Print array1(k) DrawingAttributeCT = DrawingAttributeCT + 1 Next j End If End If Next End Sub The attributes are in an array called array1. This works in my form module but when I move it to a class module I get array1 is not readable. Anyone have any ideal why this happens and is there any sample code that gets attribute in a class module? Thank you, Quote
