FazBear Posted September 30, 2008 Posted September 30, 2008 hi all I am a bit of a newbie where lisp is involved, all i need to do is write the x distance between 2 points to a variable. can anyone help? Quote
lpseifert Posted September 30, 2008 Posted September 30, 2008 (defun c:test () (setq p1 (getpoint "Pick first point: ") p1x (car p1) p2x (car (getpoint "Pick second point: " p1)) xdist (abs (- p1x p2x)) ) (alert (strcat "The X distance between the two points is " (rtos xdist 2 2) "\nand is saved in the variable Xdist")) (princ) ) Quote
CAB Posted October 1, 2008 Posted October 1, 2008 (setq p1 (getpoint "\nPick 1st point.")) (setq p2 (getpoint "\nPick 2nd point.")) (setq x (distance p1 p2)) Quote
FazBear Posted October 1, 2008 Author Posted October 1, 2008 Thank you for the replies seems so somple now :S Quote
FazBear Posted October 1, 2008 Author Posted October 1, 2008 Ended up using ASMI's method, just tweaked it to a more simple format (for me to understand). Thanks again! (defun c:signage () (setq POINT1 (getpoint "Pick Top Left: ")) (setq POINT2 (getpoint POINT1 "Pick Bottom Right Corner: ")) (setq POINT1X (car POINT1)) (setq POINT2X (car POINT2)) (setq XDIST (- POINT2X POINT1X)) (setq POINT1Y (cadr POINT1)) (setq POINT2Y (cadr POINT2)) (setq YDIST (- POINT1Y POINT2Y)) (alert (strcat "The X distance between the two points is "(rtos XDIST 2 2) "\nThe Y distance between the two points is "(rtos YDIST 2 2))) ) Quote
