Ivisible Line to contain BHATCH?
Is their a way to create a line only visible in autocad but one that will not print.
I want to confine some bhatch within a particular area but do not want the boundry of the shape to be seen, i.e, an invisible line that does not print would do the trick.
Or is their a way to keep the hatch contained if I delete the boundary shape?
Put the boundary on Defpoints layer (not necessarily recommended) or on a 'no plot' layer
You can delete the boundary, if the hatch is associative, Acad will notify you that the associativity has been removed
Thanks, for the help. I run a customized version of autocad that brings in most of the layers automatically or I just do match layer to change when needed.
Played in layers and have seen where you can turn printer on/off.
Deleted border and at least for now the bhatch did not run amuck all over the page.
