Hello!
I was wondering if anyone could share their workflow or suggestions for setting up a CAD block library.
I have been collecting blocks of furniture and plants for CAD projects into a single dwg file - my library. I then copy & paste the blocks as needed into my project file. Usually I have to BEDIT them to change layer & then scale to size. I have tried adding blocks to the Tool Palette with no success.
I know my workflow is totally newbie & there must be a more efficient way! Thanks in advance for any input.
Tollpalettes is the best way to do what you want. We have several CAD-Standards implemented using palettes.
Check out Michaels' Corner on this site and the Case Study at this link: http://www.autocadtrainerguy.com/
That should sort out your problems.
why are you BEDITing them to change layer? If you define your blocks on layer 0 they will take on the properties of whatever layer you put them on.
I would also recommend that you persevere with tool palettes, they are great for often used blocks although we still maintain individual files for other blocks that would clutter up a palette. These are stored in a folder in the search path so can be brought in to the current drawing with a simple INSERT command.
I don't use th eDesign Centre but this can also be used to fetch a block from another drawing.
Tool palettes would be the most logical way to go followed by the use of Design Center. An Internet search could easily find a handful of good tutorials about creating a custom Tool Palette. Other options include AutoCAD Help, your AutoCAD User's Guide, AutoCAD Customization Guide and/or a good after-market AutoCAD book.
AutoCAD 2010 - Customize Tool Palettes
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS73099cc142f48755-1257e12111bf108800e-10a.htm,topicNumber=d0e6816
Edited by ReMark
Thanks- i didn't know about the 0 layer and I'm going to give to another try! :)
