I just wanted to know if anyone has any documentation for the POL-Fill.lsp program, made by David Bethel. I just tried it, and although it seems to make 3d faces from the polyline, it seems to make them extremely high (sorry for the terminology, but I don't know what to call it). It seems like no matter where the ucs is or what viewport I'm in, the 3d Faces seems to jet off to the side (plus they seem to "flatten out" at the end). I've tried every view possible, and setting the UCS, but it still seems to go off to the same side. Is there any way to only make it a minimal "height". Basically I'm trying to take a polyline with multiple curves and add a texture to it. Thats why I need a 3d face. Basically I'm trying to make a hatch pattern with a texture. Sorry if there is an easy solution. I am a newbie when it comes to 3D Autocad
  • 13 years later...
I'll assume you got the LISP from the link below? Might be a better place to ask for help - the author was last online in September and if he sees posts might come back to answer and advise?
