Convert spline into polyline.
Hi. everybody. can anyone help me to solve this problem. i have one drawing but this is Spline but i want to convert it into polyline. without tracing it. i attach my dwg file with this massage. thanks
It isn't possible in ACAD or ACA 2007 without coding (AutoLISP or ARX), but in ACAD 2012 it is an option of SPLINEDIT command.
Command: splinedit
Select spline:
Enter an option [Close/Join/Fit data/Edit vertex/convert to Polyline/Reverse/Undo/eXit] <eXit>:
How about saving as R12 DXF. No coding with that :D
I saw the link in KramerO's post just after sending my reply, so you and KramerO are right. For learning this I thank you both.
Command: splinedit
Select spline:
That is handy to know, thanks. Just installed AutoCad and Civil 3D 2012 at the end of last week and will start to transition into them.
Thanks to reply my post. its works thanks again.
  • 2 years later...
You can try out the new SPLINECAM app in Autodesk AppStore or download it from autocam2d.com/download link.
Appstore link : http://apps.exchange.autodesk.com/ACD/en/Home/Index
It converts splines to polylines/polyarcs with optimal number of vertices and smoothness.
regards
cncpatriot
I think you may have missed a few threads. Keep looking.
Right click on the spline, go to the spline menu and select convert to polyline, select your degree of accuracy and your done.
I just tried that and it didn't work for me.
What g-code is a polyline?
AFAIK the question was to convert to arcs (which would return in CAM software G02 or G03).
http://www.cnccookbook.com/CCCNCGCodeArcsG02G03.htm
Edit: never mind - I didn't read the entire thread and got this one confused with one of the other resurrected threads.
