Get all lines in a 2d drawing on the same plane so i can hatch
I tried to hatch on both acad 2002 & 2010 with the same drawing. It is a simple rectangle. It won't fillet the 2 locations that the red circles display. In acad 2010, when you try to hatch in either "select internal point" or "select objects", a message comes up "lines are not coplanar". How can you bring all the lines, no matter what layer they are in, onto the same plane.
Please reply
bob finley
It is not something I would advise, although you can use the FLATTEN command.
If you want to set just the lines to the ame Z value you can also use QSELECT to select all lines in the drawing and then in the properties pane set the start and end Z values to the value you want. They are then all coplanar.
Hi
i tried the flatten comand and it worked fine. Why would you not advise to use it.
Regards
bob finley
Different strokes for different folks. Use whatever works for you. Consider any other method a "fail-safe" in case the one you use does not work.
