Is there any way to add the Trace command back into AutoCAD 2012, I used it alot on older versions and now I'm having to draw a solid block !!!! not happy about this removal !!!!!
Type REDEFINE into the command line, followed by TRACE
Thanks Dink, worked perfect !!!!
Also thank you for the quick response !!!!
