il0veaut0cad Posted April 25, 2011 Posted April 25, 2011 Hello everybody in cadtutor.net. First of all, I would like to say that I really admire cadtutor. To everyone who's behind this and to everyone who helps beginners (like me) dig more steep knowledge about AutoCAD. I am very thankful to have cadtutor. Now, about my concern, I'm really not that good in AutoCAD especially when it comes to 3D. I am still a beginner and very eager to learn more. I started from 2d and learned my way up into a little bit of 3D. I can say that I'm really not that guided if I'm doing stuffs or inputting the commands correctly. Right now, I'm practicing and STILL on a journey on how to create a 3d roof technically correct. I attached the whole layout here. Hope you share me some of the techniques. Thanks a LOT LOT LOT! P.S. Sorry if I talked too much.:D NEED UR HELP.dwg Quote
tzframpton Posted April 25, 2011 Posted April 25, 2011 Here's a good video I ran across a few months ago. This will get you started. You can then use more solid modeling editing commands to create the flat faced "gable" style roof once you have the overall roof extruded. [video=youtube;2OHx4a-3VBQ] Quote
BIGAL Posted April 27, 2011 Posted April 27, 2011 If you want to stay away from 3d Solids you can also use "pface" to make roofs the only problem is that you have to join 3d points together, yes it can be done via lisp for gable, straights valleys, hips, multi pts etc sorry its copy righted software. basicly you join pfaces together. Quote
f700es Posted April 27, 2011 Posted April 27, 2011 Start simple! Make a simple "ranch" style house and make a roof for that. Then build on that experience. Quote
vukstefanovski Posted October 24, 2011 Posted October 24, 2011 Hello to everyone. I have one roof but I can't do this "move faces" or "offset faces" because it says: "Modeling Operation Error: Change in topology detected" (AutoCAD 2010) and: "Modeling Operation Error: Gap cannot be filled" (AutoCAD 2012) Please help, and sorry for bad english, I hope you understand. Quote
ReMark Posted October 24, 2011 Posted October 24, 2011 Sounds like your geometry might be a bit off. Quote
vukstefanovski Posted October 24, 2011 Posted October 24, 2011 Sounds like your geometry might be a bit off. No, I tried 100 times, it is always the same... Quote
vukstefanovski Posted October 24, 2011 Posted October 24, 2011 Something like this Drawing1.dwg Quote
mihaela Posted November 28, 2013 Posted November 28, 2013 i have the same issue. When i try to build a roof in autocad 2010, i apply the solid edit command and then after typing face and move this error apear. Can somebody help me? Modeling Operation Error: Change in topology detected. casa.dwg Quote
samchums26 Posted November 28, 2013 Posted November 28, 2013 you need to start with a simple roof design. attach is the roof 3d i made 3 years ago... ROOF.dwg Quote
ReMark Posted November 28, 2013 Posted November 28, 2013 mihaela's roof is a simple design. It's basically flat as only the edges are sloped. Not that I like that particular design but flat roofs are used all over the world. mihaela: Did you intend the roof to be flat or peaked? Quote
