Two questions that have not been asked often, maybe...
All,
I am inquiring about how to add the ' apostrophe function to my programs.
And how to have your ssget recognize objects selected prior to command start.
Any thoughts?
Kind Regards,
Matt
(setvar 'Pickfirst 1)(ssget "_I" )
Can you explain more clearly about your aim?
By apostrophe, I'm assuming you mean running the command transparently.
If so, any LISP routine can be executed transparently IF and on IF it does NOT have any command calls.
eg.
(defun c:L0 (/ ss i)
 (if (setq ss (ssget "_:L"))
     (entmod (list '(8 . "0") (cons -1 (ssname ss (setq i (1- i))))))
If you notice, this can be executed transparently by typing 'L0 at any time AND if objects are selected before the routine is executed, it will process said objects, thus suppressing the prompt to select objects.
ssget will detect an existing selection, regardless of whether the Implied "_I" mode string is used.
As for the apostrophe, I'm unsure as to whether you are referring to marking expressions as literals or running a function transparently within a command. If it is the former, read this:
http://www.cadtutor.net/forum/showpost.php?p=258390&postcount=20
Lee
I use ssget in the majority of my commands and if i have a selection set prior to launching the command it does not recognize the set.
Matt
Do you have a command call before the ssget call? Also, check our pickfirst variable.
Edited by alanjt
ssget will detect an existing selection, regardless of whether the Implied "_I" mode string is used.]
Lee
You are right Lee, just to add some necessry explanations:
1- If Pickfirst system variable is set to 1, (ssget) detects existing selection.
2- If Pickfirst is set to 0, (ssget) prompts user to select desired objects.
So what is the task of "_I"? I think NOTHING.
Perhaps for when PICKFIRST is set to 0... I wouldn't know, I always have it set to 1.
I tested that. It returnes a value and doesn't wait for user input or selection. This is the differnce of (ssget "_I") with (ssget).
Pickfirst=0, a selection set exists: (ssget "_I") returns nil
Pickfirst=1, no selection set exists: (ssget "_I") returns nil
Pickfirst=1, a selection set exists: (ssget "_I") returns
