naghshe Posted April 27, 2011 Posted April 27, 2011 I am trying to rotate and translate some points I imported in LD04. When I go to points-->edit points--> rotate points it asks me: "autodesk point database setup must be in single-user mode to use command" How do I change to single mode? since I'm the only one using this computer at home. Thanks Quote
KJB Posted April 27, 2011 Posted April 27, 2011 I believe you need to set the variable SDI to 1. Be sure to only have one drawing open. Quote
naghshe Posted April 27, 2011 Author Posted April 27, 2011 I tried what you said but it says" The current setting for SDI is required by a loaded application. Cannot set SDI to that value." Quote
SLW210 Posted April 27, 2011 Posted April 27, 2011 Are you running a third party add-on? Nevermind, I noticed you are using LDD 2004 and not AutoCAD 2004. From Autodesk knowledgebase "LDD doesnt support multidrawing". Quote
KJB Posted April 27, 2011 Posted April 27, 2011 Maybe this will help: http://www.cadtutor.net/forum/archive/index.php/t-53246.html Quote
