hii !!
my programme suppose to loop in 2 list (ptinslist and li )to applicate the translate function.. the first loop worked but the k one doesn't work
plzz help
(setq k 0)
(setq j 0)
(while (
(while (
(setq tran (translate (nth k ptinslist)(nth j li)))
(setq nvlist (append nvlist (list tran)))
(setq j (+ j 1))
(setq all (append all (list nvlist)))
(setq k (+ k 1))
  • Replies 36
  • alanjt
    15
  • SOliver
    8
  • yajis_narif
    8
  • BlackBox
    3
Popular Days
Posted Images
I have changed the title of your thread to something more descriptive, please use more descriptive titles in the futre, it helps.
Your snippet is rather confusing, but I think you can accomplish what you are after with mapcar+lambda.
eg.
(mapcar '(lambda (a b) (translate a b))
       ptinlist
       li
BTW, translate is not a native function, so I'm assuming it's one you wrote. If it's trans you are trying for, then you'll need three arguments, not two.
ok tiger i will thanks
alanjit yes translate is a function :
(defun translate (pt1 pt2 /)
(mapcar' + pt1 pt2)
but i need to loop in the two list (the length of the two list is 4 )
(mapcar '(lambda (a b) (apply 'mapcar (cons '+ (list a b))))
       ptinlist
       li
If you're intending on goin' with your original code I'd suggest it was written similar to below - for neatnes etc.
(setq k -1)
(while (< (setq k(1+ k)) Lins)
 (setq j -1)
 (while ( < (setq j(1+ j)) Lcord)
I'm with alanjt on this one since you're iterating through lists although I think it would need to be
(mapcar '(lambda(x)
 (mapcar '(lambda(y)
   (translate x y))
   Lcoord))
 Lins)
It depends on what you're trying to achieve: if you're trying to translate every point in Lcoord against every point in Lins then the above mapcar cluster is probably what you're looking for. If you're trying to run translate against each lists' respective coordinate e.g
(setq lins (list 0 10 20))
(setq lCoord (list 5 60 80))
;Example point
(translate (nth 0 lins)(nth 0 lCoord))
(translate (nth 1 lins)(nth 1 lCoord))
(translate (nth 2 lins)(nth 2 lCoord))
then you want to go with alanjt's suggestion - which I believe is what you're looking for however; you're posted code is trying to do the solution I've provided.
Hope that helps
EDIT: Before someone shoots my foot off; all code was written in the respond to thread area and therefore hasn't been tested. Other than the possiblity of an extra right paren or syntax error the principle is sound. :)
If using the subroutine, I think it should look like this:
(mapcar '(lambda (a b) (translate a b)) ptinlist li)
thanks every one i will try this and reply
for the code i'm trying to do this :
;Example point
(translate (nth 0 lins)(nth 1 lCoord))
(translate (nth 0 lins)(nth 2 lCoord))
(translate (nth 1 lins)(nth 0 lCoord))
(translate (nth 1 lins)(nth 2 lCoord))
(translate (nth 2 lins)(nth 0 lCoord))
(translate (nth 2 lins)(nth 1 lCoord))
I'm confused, is it a list of points or a list of integers?
integers: '(0 1 2 3 4 5 6)
no i'ts a list of points actually they are coordinate
In that case use the above (and now below)
(mapcar '(lambda(x)
  (mapcar '(lambda(y)
    (translate x y))
    Lcoord))
  Lins)
yajis_narif,
Please place your codes between code tags. (Just hit the # symbol near the smilies).
Thank you.
(mapcar '(lambda(x)
  (mapcar '(lambda(y)
    (translate x y))
    Lcoord))
  Lins)
i'm not that good with the lambda function but doeas this loop into the list actually this code worked
(while (
(setq j -1)
(while (
but it return one list of all coordinates actually the first list is a list of four coordinate and the second list is a list of four points too
i want to add the first four coordinate to eatch points of the secons list and return a list of 4 list in it
i'm sorry i'm not that good in english ^^
yajis_narif,
Thank you.
Better do what he says; you won't like him when he's angry.
ok i'm sorry i'm new here so... i will do what he says :)
thanks
thanks
I see what you did there...... :lol:
yes yes i know ... he is already angry i guess :sweat:
You big bully! Do your little girls know you're such a meany to new kids!? :lol: LoL
Edit - (^^ I too am only joking with a friend ^^)
