Interior walls won't show up in Revit Architecture 2011-Help!!
I've been trying to put up interior walls for the last hour, going through every option I know and googling all kinds of different solutions. I still can't remember how to fix this error:
None of the created elements are visible in Floor Plan: First Floor View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
I don't remember how to fix it, and I can't find an answer. Help please!
When starting to draw the wall, in the Properties dialog, is the base set to First Floor?
Are you drawing the wall in the correct phase?
Is your views' Phase Filter set to show the Phase in which you're drawing the wall?
