BlackBox Posted May 3, 2011 Posted May 3, 2011 As Reference Manager can only change the path to External References, and not the name of the reference drawing itself (which I need to do), I'm looking into correcting a set of drawings using ObjectDBX. I've been successful at adding XREFs to ODBX drawings in the past using vla-AttachExternalReference, but am not understanding why I am receiving this error when attempting to detach: ; error: Automation Error. Description was not provided. Here is my 'working' code at the moment: (defun c:FOO (/ sheets path dbx n oXref) (vl-load-com) (if (and (setq sheets (vl-directory-files (setq path "[color=blue]SomePath[/color]\\") "*.dwg" 1)) (setq dbx (vla-GetInterfaceObject (vlax-Get-Acad-Object) (strcat "ObjectDBX.AxDbDocument." (substr (getvar 'acadver) 1 2))))) (progn (foreach sheet sheets (vl-catch-all-apply 'vla-open (list dbx (strcat path sheet))) (vlax-for x (setq oLayoutBlock (vla-get-block (vla-item (vla-get-layouts dbx) "Model"))) (if (and (= "AcDbBlockReference" (vla-get-objectname x)) (vl-position (setq n (vla-get-effectivename x)) '("[color=blue]XREF1[/color]" "[color=blue]XREF2[/color]")) (= :vlax-true (vla-get-isxref (setq oXref (vla-item (vla-get-blocks dbx) n))))) [b][color=red]([/color][/b]vla-detach oXref))) [color=green];<- This line errors [/color] (vl-catch-all-apply 'vla-saveas (list dbx (strcat path sheet)))) (setq dbx (vl-catch-all-apply 'vlax-release-object (list dbx))))) (princ)) Note - Error checking not included, as this is only working code. Quote
SOliver Posted May 3, 2011 Posted May 3, 2011 I think you need to reference the document as the first parameter and then the xref as a second (vla-detach dbx oXref) Quote
BlackBox Posted May 3, 2011 Author Posted May 3, 2011 Soliver, I appreciate the suggestion. Despite the parameters listed in the Developer Documentation, I tried your suggestion anyways with no success. See the error returned: ; error: ActiveX Server returned the error: unknown name: Detach ... As the ODBX Document Object does not inherit the Detach Method. Detach Method Detaches an external reference (xref) from a drawing. Signature object.Detach() Object Block The object this method applies to. Remarks Detaching an xref removes the xref from the current drawing. All copies of the xref are erased, and the xref definition is deleted. All xref-dependent symbol table information (such as layers and linetypes) is deleted from the current drawing. You cannot detach an xref that contains other xrefs. Quote
SOliver Posted May 3, 2011 Posted May 3, 2011 Heavy I think this post covers it: http://www.cadtutor.net/forum/archive/index.php/t-44133.html I reckon the following is roughly what you're looking for from the link. (vlax-for block (setq blocks(vla-get-blocks dbx))) (if(= (vla-get-isXRef block) :vlax-true) (vla-detach block) ) ) Quote
wishbonesr Posted November 2, 2012 Posted November 2, 2012 RenderMan, Did you ever resolve this? Quote
BlackBox Posted November 3, 2012 Author Posted November 3, 2012 RenderMan,Did you ever resolve this? Knowing full well that I am willingly, officially zombifying this thread.... Wow I was bad about posting my solution back then... I did, and will dig through my toolbox to see if I cannot find what I used. I've learned a lot since back then, and may have changed code for other uses, etc.. Is there something specific your needing other than what I describe above? Quote
BlackBox Posted November 3, 2012 Author Posted November 3, 2012 Of course, were I coding this new, I'd probably use the .NET API... Specifically ReadDwgFile() and Autodesk.AutoCAD.Internal.Utils.WcMatch(string, string) Methods. Quote
wishbonesr Posted November 4, 2012 Posted November 4, 2012 Is there something specific your needing other than what I describe above? Specifically. Detaching an xref from a drawing that is opened with dbx. I'm converting a lisp that originally only functioned in the current session. Now I wish to convert to batch processing with dbx. I'm just not there in .net yet. vla-detach works in the current session, but fails in dbx - exactly the problem you had. How did you wind up detaching while in dbx? One suggestion was to vla-delete = failed The post suggested by SOliver also did not solve. Couldn't really tell if Joro was getting results and Lee was trying to troubleshoot..??, or if Lee hadn't tested the concept first?? Either way, it was a similar issue. Lee's code generated the Automation error without vla-catch-all-apply. I would have started a new post, but I didn't see that age of this post in my browser. Thanks for looking back into this. Quote
BlackBox Posted November 4, 2012 Author Posted November 4, 2012 It was so long ago, I honestly do not remember how I got around this... I'll see what I can find, and post back. Quote
Lee Mac Posted November 4, 2012 Posted November 4, 2012 As far as I know, XRefs are not loaded in drawings opened with ObjectDBX and hence cannot be detached. Quote
wishbonesr Posted November 5, 2012 Posted November 5, 2012 As far as I know, XRefs are not loaded in drawings opened with ObjectDBX and hence cannot be detached. Is there any substance to ronjonp's post about removing references to the xrefs'? http://www.cadtutor.net/forum/showthread.php?p=299135#post299135 Quote
BlackBox Posted November 5, 2012 Author Posted November 5, 2012 Is there any substance to ronjonp's post about removing references to the xrefs'?http://www.cadtutor.net/forum/showthread.php?p=299135#post299135 What happened when you tested this for yourself? I've just tested the Erase() Method here, and all is well... Just be sure to erase the entity, and not the block definition (even though you need to test this for IsXref), and also test for locked layers, and restore as needed. HTH Quote
wishbonesr Posted November 6, 2012 Posted November 6, 2012 (edited) What happened when you tested this for yourself? I did, but was attempting to delete the blockdef - which of course generated an automation error I've just tested the Erase() Method here, and all is well... Just be sure to erase the entity, and not the block definition (even though you need to test this for IsXref), and also test for locked layers, and restore as needed. HTH That would be a solution if I were trying to create an Unreferenced xref. The xref's I'm removing are based on the user's selection to Remove Unreferenced Remove Unloaded Remove FileNotFound or any combination Namely, my testing first centered on Unreferenced types, which means there are no inserts to Erase() (vla-erase). I sure do like to create lisp packages that function wholy without other languages, but I'm starting to finally understand autolisp's limitations. A complete side note... vla-IsXref will also return nested xref's. There's a way to elliminate nested xref's in lisp, but it involves making a list of subnested xref's and their xref's, etc., so if a tested xref is a member of the nested list, then it's a nest, not a direct. LeeMac has a routine that does that (xreflist me thinks). Negating that, I used a seperate .net LispFunction that simply returns the result of .net .IsFromExternalReference, which eliminates attempts to detach a nested xref. The following code bits are my final the result... minus good LispFunction var handling (see http://www.theswamp.org/index.php?topic=43063.msg483195#msg483195) The following is the function called during the dbx operations. The var "cd: xrefclean: operation" is a vl-propagate'd and contains the initial command that obtained the user's options. (defun cd:clean-xref (dbxdoc / cd:detach status statuses blk blocks blockname detach outdata ename reflist ref vla_ref ) (defun cd:detach (xref /) ;(vla-detach xref) ;(vla-delete xref) ;(vla-erase xref) (cd:xref-detach (vlax-vla-object->ename xref)) );defun cd:detach (setq blocks (vla-get-Blocks doc)) ;make a collection list of all true xref block enames (vlax-for blk blocks (if (and (= :vlax-true (vla-get-isxref blk)) (setq ename (vlax-vla-object->ename blk)) (cd:block-isxref ename)) ;(setq blockname (vla-get-name blk)) ;get it now before it's deleted ;(setq blockpath (vla-get-path blk))) ;build a list first, then submit to .net to get results all at once. (setq reflist (append reflist (list ename))) );if );vlax-for blk in blocks (if (and (< 0 (length reflist)) (setq statuses (cd:xref-status reflist))) (foreach ref statuses (setq detach nil status (cdr ref) vla_ref (vlax-ename->vla-object (car ref)) blockname (vla-get-name vla_ref) blockpath (vla-get-path vla_ref)) (if (and (not detach) (wcmatch cd:xrefclean:operation "*R*") (= status "Unreferenced")) (setq detach (cd:detach vla_ref)) ) (if (and (not detach) (wcmatch cd:xrefclean:operation "*F*") (or (= status "FileNotFound") (= status "Unresolved"))) (setq detach (cd:detach vla_ref)) ) (if (and (not detach) (wcmatch cd:xrefclean:operation "*L*") (= status "Unloaded")) (setq detach (cd:detach vla_ref)) ) (if (and (not detach) (wcmatch cd:xrefclean:operation "*A*") (or (= status "FileNotFound") (= status "Unloaded") (= status "Unresolved") (= status "Unreferenced"))) (setq detach (cd:detach vla_ref)) ) (setq outdata (cons (list blockname status (if detach "Detached" "Remains Attached") blockpath) outdata) ) );foreach ref in reflist );if outdata );defun cd:clean-xref -Split into two posts. Edited November 6, 2012 by wishbonesr Quote
wishbonesr Posted November 6, 2012 Posted November 6, 2012 -Continued The first step was to ensure the block def wasn't a nested block. [LispFunction("cd:block-isxref")] public bool Block_isXref(ResultBuffer rb) { if (rb == null) { return false; } TypedValue[] args = rb.AsArray(); if (args.Length > 1 || (LispDataType)args[0].TypeCode != LispDataType.ObjectId) { return false; } ObjectId ObjId = (ObjectId)args[0].Value; using (Transaction tr = ObjId.Database.TransactionManager.StartTransaction()) { try { BlockTableRecord btr = (BlockTableRecord)tr.GetObject(ObjId, OpenMode.ForRead, false); if (btr.IsFromExternalReference) return true; } catch (System.Exception) { tr.Abort(); return false; } } return false; } The next step was to get an accurate status of the xref. It was important that the function only invoked .ResolveXrefs() once per dbx drawing, thus the need to send it a list of enames/objectid's to work with. [LispFunction("cd:xref-status")] public object Xref_Status(ResultBuffer rb) { if (rb == null) { return false; } TypedValue[] args = rb.AsArray(); ObjectId ObjId = new ObjectId(); if (args.Length == 1) { ObjId = (ObjectId)args[0].Value; } else { ObjId = (ObjectId)args[1].Value; } using (Transaction tr = ObjId.Database.TransactionManager.StartTransaction()) { ResultBuffer res = new ResultBuffer(); try { res.Add(new TypedValue((int)LispDataType.ListBegin)); if (!HostApplicationServices.WorkingDatabase.Equals(ObjId.Database)) ObjId.Database.ResolveXrefs(true, false); foreach (TypedValue arg in args) { try { BlockTableRecord btr = (BlockTableRecord)tr.GetObject((ObjectId)arg.Value, OpenMode.ForRead, false); res.Add(new TypedValue((int)LispDataType.ListBegin)); res.Add(new TypedValue((int)LispDataType.ObjectId, (ObjectId)arg.Value)); res.Add(new TypedValue((int)LispDataType.Text, btr.XrefStatus.ToString())); res.Add(new TypedValue((int)LispDataType.DottedPair)); } catch (System.Exception) { } } res.Add(new TypedValue((int)LispDataType.ListEnd)); return res; } catch (System.Exception) { tr.Abort(); res.Add(new TypedValue((int)LispDataType.ListEnd)); return false; } } } And finally, function to detach the file using .net. [LispFunction("cd:xref-detach")] public Boolean Xref_Detach(ResultBuffer rb) { if (rb == null) { return false; } TypedValue[] args = rb.AsArray(); if (args.Length > 1 || (LispDataType)args[0].TypeCode != LispDataType.ObjectId) { return false; } ObjectId objId = (ObjectId)args[0].Value; using (Transaction tr = objId.Database.TransactionManager.StartTransaction()) { try { BlockTableRecord btr = (BlockTableRecord)tr.GetObject(objId, OpenMode.ForRead, false); if (btr.IsFromExternalReference == true) { objId.Database.DetachXref(objId); tr.Commit(); return true; } else return false; } catch (System.Exception) { tr.Abort(); return false; } } } Quote
BlackBox Posted November 6, 2012 Author Posted November 6, 2012 Sorry to nitpick, but the cd : detach and cd : xrefclean : operation LispFunction Methods appear to be missing, and you've posted cd : xref-detach (the Xref_Detach() Method) instead. Also, you really should make use of either Gile's LispException* Classes that I mentioned in your other thread at TheSwamp, or the code contract that Tony offered in his prototype design, rather than simply having an empty catch statement that neither handles the exception, nor reports to you what went wrong. They may be interchangeable (I honestly have not tried it for myself), but generally one would return bool value in lieu of a Boolean Class type... Compare your Block_isXref() and Xref_Detach() Methods. Just to throw the idea out there for your consideration, might I suggest that instead of creating separate LispFuntion Methods for each Block_isXref(), Xref_Status(), and Xref_Detach(), that you instead consider (for this specific task) coding a single, (bit-coded?) XrefDetachIf() Method. While functional, and also an enhancement to LISP as is, I think you'll find a significant increase in performance, if you simply take a step back and plan your plug-in around what you're actually attempting to do here. Were you to use a single XrefDetachIf() Method, you would reduce your overhead as you would need only a single Transaction for each call to the LispFunction Method, as compared to using each of the three LispFunction Methods you posted above. Considering what your LISP does now.... For each DBX Document, you iterate the Block Collection, and test each using Block_isXref() (1+ Transaction for each call) in order to build a list of Block References that are External References. Next, you iterate the resultant list of External References, testing for Xref_Status() (1+ Transaction for each call)... This step you do good, by utilizing the ResultBuffer to pass ObjectId[] as an argument. However, were you to effectively code a XrefDetachIf() LispFunction Method, you would preclude the need to build a valid list of External References, and then iterate that list to determine which are of a particular status in the first place, and simply pass ObjectId[] for a given DBX Document's Block's eNames (as you do for Xref_Status() ), and the internal .NET logic would minimize the processing, sorting, and 'meat' of the LISP routine for you. HTH Quote
BlackBox Posted November 6, 2012 Author Posted November 6, 2012 Pseudo code: /// <summary> /// First argument - ObjectId[] of enames /// Second argument - Bit-coded value for external /// reference statuses to filter for: /// /// 1 FileNotFound /// 2 Nested /// 4 Unloaded /// 8 Unreferenced /// /// Third argument - Reload unloaded references (T / nil) /// /// Example: /// (Xref-Detach-If listOfXrefEnames 9 T) /// </summary> /// <param name="res"></param> /// <returns></returns> [LispFunction("Xref-Detach-If")] public ResultBuffer XrefDetachIf(ResultBuffer res) { } Quote
wishbonesr Posted November 6, 2012 Posted November 6, 2012 (edited) I've formed a response twice, and this forum has timed me out twice and it lost my composition. Actually more than twice, but I copied my response before preview a few times. This time though I just forgot. Must mean I should not post today. Is it like 3 minutes or something???? Well... I guess the point of my reply was a big thank you for the pointers and guidance. ...cd : detach and cd : xrefclean : operation LispFunction Methods appear to be missing, and you've posted cd : xref-detach (the Xref_Detach() Method) instead. cd : detach is a nested defun. It's there cd : xrefclean : operation is a text var, not a defun, begotten from the c:xrefclean wrapper command Here's a snip of that section (initget "L R F A LR LF LRF LFR RL RF RFL RLF FL FR FLR FRL") (princ "\nYou can use any combination like RF or FL") (setq cd:xrefclean:operation (getkword "\nXref Cleaner: Detach [un(R)eferenced/Not-(F)ound/Un(L)oaded/(A)ll-Non-Displayed] <A>: ")) Also, you really should make use of either Gile's LispException* Classes that I mentioned in your other thread at TheSwamp, or the code contract that Tony offered in his prototype design, rather than simply having an empty catch statement that neither handles the exception, nor reports to you what went wrong. Referenced that post, and gave mea culpas They may be interchangeable (I honestly have not tried it for myself), but generally one would return bool value in lieu of a Boolean Class type... Compare your Block_isXref() and Xref_Detach() Methods. Good catch. vs autocomplete The rest of your suggestion is sound advice. What I accidentally found out, while proving your suggestion was that vla-get-isxref provides a considerable time savings, as it filters out blocks defs that are not xref's at all. Elapsed milliseconds / relative speed for 512 iteration(s): (CD:XREFTEST1 XREFLIST)......13634 / 19.58 <fastest> (CD:XREFTEST2 XREFLIST).....266996 / 1.00 <slowest> The above xreflist is a 1432 length vla-object collection of vla-get-blocks. 383 are actuall xref's and 9 are direct xref's. Both functions use your suggested method of combining the cd : block-isxref and cd : xref-status into a single function. I left the determination of whether to detach to lisp. So the difference in the above function tests are that cd : xreftest1 included a pre-test for vla-get-isxref, while cd : xreftest2 sent every block def to be tested in .net. After reminiscing. I believe I will still keep it seperate. Each Lisp Function I've created has a specific role; that thought actually did go into creating the functions, as my intention was to expand lisp in the spirit of lisp. Where logic is kept in lisp, and the lispfunctions provide expanded capability. For instance. It could be thought that having a function to return boolean for IsUnloaded, is IsResolved, and IsFromExternalReference, might be condiered obsolete if I just returned the string for XrefStatus, however I can envision scenarios where each would serve purpose in the situation needed. I just realized I took this thread over. I'm gratefull I stumbled on your original post, because I'd be further behind the curve than I already am. Sincerely, Edited November 6, 2012 by wishbonesr Forum kept timing out. But finally edited to include intended post. Quote
BlackBox Posted November 6, 2012 Author Posted November 6, 2012 I've formed a response twice, and this forum has timed me out twice and it lost my composition. Actually more than twice, but I copied my response before preview a few times. This time though I just forgot. Must mean I should not post today. Is it like 3 minutes or something???? Well... I guess the point of my reply was a big thank you for the pointers and guidance. You're welcome; I'm happy to help. Perhaps I should have broken things out a bit more, but I wanted to 'get it all in' before I left work to vote. Again, as you already know from my participation over at TheSwamp, I am no expert when it comes to the finer points of .NET, but I genuinely hope that my comments are of help to you. Quote
BlackBox Posted November 7, 2012 Author Posted November 7, 2012 I just realized I took this thread over. I'm gratefull I stumbled on your original post, because I'd be further behind the curve than I already am. No worries; I too am glad you chimed in. I've been wanting to delve more and more into .NET development, but often do not make the time to plan out my own initiatives (I do it all in my spare time), so more often than not helping others with their interests is something I look for first. Besides, I think your LispFunction Methods would make a good addition to this thread, where I may very well code that XrefDetachIf() LispFunction also. Quote
